does anyone has the link for the watsh you can use whit ARC?
— Edited
PWM Slider
— Slider to set EZ-B digital PWM for motor speed or LED brightness; shows duty-cycle, stop button, and board/port selection.
Are you trying to say "watch" as in wrist watch that you wear on your wrist to keep time?
https://www.newark.com/texas-instruments/ez430-chronos-915/cc430-rf-wireless-watch-915mhz/dp/51R4690?mckv=sPDx3n6Mc|pcrid|41566056141|plid|&CMP=KNC-GPLA
Its the TEXAS INSTRUMENTS EZ430-CHRONOS dev kit. If you do a search for that you might find a local supplier. I don't think the kit is very popular, so you may not find many retailers.
indeed i didn find any retailers.will it be possible to let jd walk forwart&backwarts left and right whit the watch ?
thank you
Well, if you look at the control in ARC it provides a servo control for X axis and Y axis both with multi port options. For JD you'd probably need use to the variables that the watch outputs and use them in a script to make JD walk.
ah its possible then,
thank you
