Hi all
Is there a way to fire a voice command... like say Hi, then the script will say what is your name... then you say your name, and the VR holds that variable (e.g. your name) and the EZ says the variable back?
Ultrasonic Distance
— Displays HC-SR04 ultrasonic distance readings in ARC; scriptable via GetPing(), pausable, sets a variable with multiplier, optional NMS output
Hi all
Look good
I always use AIMlL Bot and Bing
I modified the XML code and added what I want it to say - works great
As for voices, audacity can make a robot voice, and with a little code here get many hidden Microsoft voices
