The V4 always disconnects when adding the compass, adding the compass via the ARC or by accessing with a i2CWrite or i2Cread from a script. Same on all three i2C ports.
Am connected to the 3.3v on the ss503 , have 20k pull ups on scl and sca and the wire length is @ 2cm.
The only way to re-establish the connection is to cycle the power on the V4.
Debug seems to indicate a timeout of some sort, but don't think the V4 should disconnected because of an i2c error .
Any suggestions or fixes , DJ, any ideas,
Thanks....
debug as follows,
Monday 29 September 2014 2:46 PM - Connected Monday 29 September 2014 2:46 PM - Setting battery monitor voltage: 6.6 Monday 29 September 2014 2:46 PM - Setting battery protection: True Monday 29 September 2014 2:46 PM - Setting i2c rate: 100000 Monday 29 September 2014 2:47 PM - Comm Err: System.IO.IOException: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. ---> System.Net.Sockets.SocketException: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond at System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) --- End of inner exception stack trace --- at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) at System.IO.Stream.ReadByte() at EZ_B.EZB.(Int32 , Byte[] ) Monday 29 September 2014 2:47 PM - BbytesToExpect: 8 Monday 29 September 2014 2:47 PM - ? Received: Monday 29 September 2014 2:47 PM - Disconnected
As mentioned by DJ the other day...
So, the EZ-B V4 will lock up when it encounters an I2C error, I presume this is why it's locking up. Check your wiring etc. (I2C and these compass modules are very temperamental at the best of times too)
Hi @Andre,
I just had the SS503 compass working on my desk.
Just as rich mentioned the EZ-B I2C circuitry will lock up if I2C communication isn't established and the Red LED by the reset button on the EZ-B will stay on until you reset power.
For my setup I had 3cm long wires, and no pullups (as the SS503 has 4.7kohm pullups on board already) and I used the right most I2C port which has traces closest to the ARM chip.
You can try using the 3 different I2C ports on the EZ-B to selectively tune the capacitance on the SDA and SCL lines and see which port might work better for you.
Hope that helps!
I haven't had time to try it yet but I was going to go with UART rather than i2X thinking it may be more stable. The manual says it can do either. Actually I am stalling hoping DJ would come through with the compass accelerometer he said was on the list. UART Compass
Chucked the i2c idea, going to the iPhone sensor streamer instead.
