Sharp IR Radar icon Sharp IR Radar — Radar-style Sharp IR scanner for EZB ADC: sweeps sensor, displays distance dots, logs ADC voltage, and can steer/avoid obstacles via Movement Panel Try it →
Resolved Resolved by Rich!
Uartwrite Question?
Uartwrite Question?
Trying to send the below code via serial to my SSC-32 servo board to test servo movement... it gives me an error because $pw is greater than 255 (max for a byte which I do understand)... It's probably me not getting it, but how do I send numbers greater than 255?
This is the error "Error on line 6: Value was either too large or too small for an unsigned byte."
$pw=1000
$m =2500
UARTInit(0,1,9600)
:start
$pw=1000
UARTWrite(0,1,"#0P",$pw,"T",$m,13)
sleep(2500)
$pw=2000
sleep(2500)
Goto(start)
Uart 0 is the regular Uart port located on the lower right side. Not one of the digital ports.
Uart 1 send is on port D5, receive is on D6.... Uart port 2 send is D18 and receive is D19... UART port 0 as Dave pointed out is the black 4 pin port on the right side of the picture he provided above...
@Dave, I don't think you can use SendSerial on UART port 0.... It doesn't seem to have a port designation (like D0 - D23) and the SendSerial command needs that as it's first parameter....
You would need to use UARTWrite on UART0
"You would need to use UARTWrite on UART0"
@Rich and @RichardR, that's what I thought. I just wanted to clarify this point. When the Sendserial command was brought up a few posts back I thought I had missed something. I've been using my Kangaroo/Sabertooth board combo on UART0 and using the UART commands with much success and am very happy with it. I just always like to know if there are any other ways to do something.
On a related note (you guys probably know this); When using the UART0 port it always has to be initialized the first time you use it after power up by using the UARTInit command.
Example: UARTInit(0, 0, 9600 ).
Once initialized you don't have to send that command again till the next power up.
Dave, a few posts back I mentioned that you needed a digital port defined in order to use the SendSerial commands. I understood the question and also knew where the UART 0 connection is located since I'm using it for sending Roomba commands. The point I was attempting to make (although poorly) was that since the UART 0 ports are not identified as single Digital ports like UART 1 and UART 2 are, that the SendSerial command cannot be used.
You are also correct that the UART port only needs one Init command as long as the EZB(4) remains powered.
Thanks @Robot-Doc, I understand now. You did not do a poor job. Your advice is always welcomed and concise. ;)
