I have a three wire Ping sensor. Can I use it with my EZBv4? I have used the normal 4 wire sensor from EZ robot but would like to use the other sensor I have available.
Thanks to All Ron
Robotis Openmanipulatorx
— Inverse kinematics for Robotis OpenManipulatorX: compute joint angles and MoveTo 3D (cm) positions, supports camera-to-CM mapping for pick-and-place.
Thanks to All Ron
Yes... you will use the same port for both trigger and echo..... don't forget to use a 5V regulator with it...
Thanks Richard, I had a feeling you might have the answer for me. I will be using it with two 4 wire sensors for avoidance, a total of 3 sensors. I assume I program it the same as the 4 wire? Ron
yep, everything should be the same....
