Sharp IR Radar icon Sharp IR Radar — Radar-style Sharp IR scanner for EZB ADC: sweeps sensor, displays distance dots, logs ADC voltage, and can steer/avoid obstacles via Movement Panel Try it →
Yes... you will use the same port for both trigger and echo..... don't forget to use a 5V regulator with it...
Thanks Richard, I had a feeling you might have the answer for me. I will be using it with two 4 wire sensors for avoidance, a total of 3 sensors. I assume I program it the same as the 4 wire? Ron
