UBTECH Alpha Servos UBT-12HC icon UBTECH Alpha Servos UBT-12HC — Control UBTECH Alpha UBT-12HC smart servos via ARC using EZ-B v4/IoTiny UART, assign virtual ports, set baud, custom bits and position mapping. Try it →
The New Rgb 8X8 Display We Are Waiting For
The NEW RGB 8x8 Display we are waiting for (taking a long time ?)
I asked a question some time ago about the SIZE of the above item so I could print a suitable housing, thanks to those that helped. BUT when I looked at EZ-Community I now have TWO sizes
text
  1.  41.46 by 39.29    /     47.64
7.18mm + led top 9mm t= 16.18 plus back part
  1.  8x8 display is 48mm (1.89 inches) x 48mm (1.89 inches) x 15.7mm (0.62 inches).
text Can anyone state which is correct ( can someone from EZ robot please answer this question)
thanks Paul UK based builder;)
The second measurement is correct. Doing some more accurate measurements with a caliper, the measurements are: 1.88" x 1.88" with the depth from the face of the display to the ezclip solder blob being ~0.63" (this measurement is dependent on how much solder is added)
hi
Thanks for you help
That a great help, I can now print the housing to hold three LCD 8x8 display units
Hope they are not long coming !
paul ;)
Early in the New year! We're switching manufacturers that can keep up with things like this.
