super HDD bionic jader gets a new arm.
— Edited
Advanced Speech Recognition
— Azure Cognitive Speech recognition for ARC with custom API credentials, scripting, language control, and text output for detected phrases
Its a 6v servo, the lipo is 7.4v of course.
Better pic, last one was horrible.
servo 6 volt.do they not get hot ?
I wouldn't know, its only for his neck so i don't think it would get hot...but i haven't powered it on yet for i don't have the right regulator for it.
Being a neck servo, i wonder if i could get away with putting 7.4v through it..its only rated for 6v and its very cheap so im sure it would go pop just by being plugged in?
did you try to use 5 volt regulator from shop here? i think that it will work.for your 6 volt servo's
i have to talk to you later.have to make myself reddy for chemo, in a few houres.
seeya
I do but its for one of the sensors, but that sensor can wait so will try it.
Good luck for your chemo amigo.
thanks by by
tomy
here the solution for the robi eyes.read this topic.they work on 3 rgb , connectors and have thousand colors.you can use 3 rgb windows. the adresses for each rgb connector are in the topic.
topic robi eyes
neon pixel bit
Thanks Nomad, just read that thread, very...very awesome.
