hello, my speech Recognition dont works, the Microphon Level are in the middle when i speak. whether German or English, I dictate text box that the robot does absolutely nothing. Do I need to install any language program?
Thank you
Picture In Picture
— Picture-in-picture camera overlay: superimpose one camera onto another; configure source/destination, position, size, border, processed frames, and swap
Thank you
Hi lispoir I presume you have looked @ https://synthiam.com/Tutorials/Default.aspx?id=12 when you give command does it appear in "speech recognition " window
Hello Bravia, Thank you for your answer in have see the Video, in the Speech Recognition Window i dont see the Command. it is black!
Ok So your commands are not getting through for some reason. Are you using win7 ? any errors when you first open EZ-B ? if not open "sound recorder" in windows and check microphone does record
Yes Win7 64bit No Errors when i open my ARC Sound Recorder and Skype works fine
in speech recognition in ezb click on setup adjust microphone levels and boost,in advanced tick "allow applications to take exclusive control of this device" Good luck
Hello Bravio, I have checked their recommendations, but unfortunately it was unsuccessful
I have testet with another Win7 PC, its the Same.
There are several reasons it's not working - In my case it was the speach recognition app in Win 7 was english based - not American. Once I matched them (same version of English as ARC) it started working. You could have the same problem or one of several others. Do a search and check all the references in this website (use google search) and you will find the answer to your problem. Speach recognition is fun but takes a lot of fine tuning and determination. Good Luck..
