Camera Click Servo icon Camera Click Servo — Interactive camera control for ARC: click-to-center and edge hotspots to pan/tilt servos, adjustable fine-tune and multi-camera support. Try it →
Soundboard Not Triggering In Mobile App
Greetings everyone!
I have a script that triggers my soundboard in ARC (Windows) but it does not trigger when I am in the mobile app. Now the mobile app is able to trigger sounds when I access the sound file directly from the soundcard in the control list but as soon as I go back to the mobile app and execute the script nothing plays.
Any suggestions? Is there a special script that I don't know about? This is only a problem in the mobile app. When I run the mobile interface from my desktop everything is fine. In the past, the sound file wouldn't transfer to my iPhone but now it does because it is playable in the control list. It's like the EZB knows it's there but doesn't want to play it as part of the script assigned to the button.
EDIT: It is important to note that I am using a Bluetooth speaker instead of the EZB speaker to play the sounds. If I disconnect the BT speaker the sounds DO NOT play over the EZB speaker. However, when the BT speaker is connected the soundcard control is able to play the sound directly from the control list. The EZB speaker is not able to trigger in any form, control list or otherwise. I never uploaded the sounds into my iPhone. They seem to have come over with the mobile app update.
Thank you,
Douglas confused confused confused confused
Thank you for finding that DJ! I made the edit and removed the soundboard script from the Fast Constant Wave Action but there was no difference.
The Soundboard control still executes the sound file within the Control List (on my iPhone) in the mobile application but it still doesn't execute the sound file upon pressing the Freak Out button (on the iPhone). If I press the Freak Out Button on my PC's desktop Mobile Interface it works perfectly, just not when I use the Mobile Interface on the iPhone.
Any ideas?
So......
Essentially (on my iPhone) it works fine with this......
But not with this.....
K I'll check something else
Fixed for the next iOS update
That's awesome! Thank you!
Any idea when voice activation will come to the mobile interface? I have this vision of R2 interacting with kids speaking into a Bluetooth mic tied to my iPhone. It'll be a smash at the Children's Hospital!
Hi DJ,
Is there a date set for the next iOS update?
Thanks!
Doug
#15
It was last updated December 15th. Check and see if that had a fix in it.
