Sharp IR Radar icon Sharp IR Radar — Radar-style Sharp IR scanner for EZB ADC: sweeps sensor, displays distance dots, logs ADC voltage, and can steer/avoid obstacles via Movement Panel Try it →
that is not supported on mobile at this time.
There is a ? (question mark) next to every X (close) button. Press the ? (question mark) on the mobile interface builder to view the manual page. Here is a direct link: https://synthiam.com/Tutorials/Help.aspx?id=196
all supported controls are listed on that page.
well, i thought it can be coded into to each soundboard file. i'll just get a W8 then .
You can edit a soundboard and add scripts to turn on and off the led. Soundboard is supported.
If you use W8, it will support all ARC functions.
The Sound servo (EZB Playback) will be added in future releases of ARC Mobile - as there's always new features being added.
but is it possible to add servo sound into the soundboard file script ?
