Servo Control Voltage
I don't have a scope to verify this but would I be correct in assuming that the servo control voltage going to the servo is 3.3 volts on any particular digital port that a servo is connected to on an EZ Controller? The power to the servo would be the battery voltage that the EZ Controller is powered up from which is typically 7.2 Volts? Thanks much.....Rick
