EZ Gauge Chart icon EZ Gauge Chart — Dashboard-style configurable gauge chart with red-zone indicator, adjustable range/arc, scale ticks, title and live value updates. Try it →
Serial Toolbox Plugin
@PTP
I have read over the tutorial on making plugins and it was very good and helpful. I am looking to do a plugin using the serial port on the ezb to communicate with an arduino type board to communicate back and forth with various sensors, lcd's, etc.
I was wonering if I could get your source code for the serial toolbox plugin to learn from regarding serial port communications with ezb, etc. I am also taking a course on c# but there is nothing like actual examples of code when it comes to communicating with hardware serial ports. Most all courses don't go into this type of coding. Thanks much....Rick. :):)
All the serial commands for the ezb can be found in...
EZ_Builder.EZBManager.EZB[0].Uart
@DJ
Thanks much, that helps but there is nothing like having a completed and working example to look over and learn from. The serial toolbox covers alot more than what was included in your awesome tutorial on plugins...Rick. :)
@DJ
Also curious as to how the serial plugin handles the arduino side of things...Rick.
Only to give a little bit of context. Rick sent me an email requesting some help to integrate an Arduino with ARC.
I will start by saying that: Arduino is not EZ you can easily open the IDE, copy paste some code, compile, flash and run.
But if you need to dig in you will need to know C/C++ language, how the libraries work, board specific details, code optimization, troubleshooting without breakpoints, limited memory, limited resources, interrupts, timers etc, etc.
Hardware used:
  1. Arduino UNO
  2. EZB V4
Arduino:
Power = USB/Cable Pins 0 - RX - Grey wire 1 - TX - Purple wire 3 - Red wire 5 - Green wire 9 - Blue wire GND - Black wire 5V - Orange wire
RGB Led (Common Cathode)
Red Led - Red wire Green Led - Green wire Blue Led - Blue wire 5v - Orange wire
EZB
Power = 7.5v Power supply Uart 0 - RX - Purple wire Uart 0 - TX - Grey wire Uart 0 - GND - Black wire (Common Ground)
Arduino Code:
  1. Libraries To make the process less complicated, i created an Arduino library called SerialCommands you can grab from here:
https://github.com/ppedro74/Arduino-SerialCommands
Please download the and install the arduino library.
i opened a ticket to publish the library via Arduino IDE tool, later you will be able to search and install automatically via Arduino IDE.
  1. Example project: https://github.com/ppedro74/ArduinoPlayground/blob/master/TestSerialCommands/TestSerialCommands.ino
Compile and flash!
Note: When flashing an Arduino with a single Serial Port (Atmega328, Atmega168) disconnect the RX/TX cables (EZB side) to avoid interferences.
Test Arduino Code:
Open the Arduino Serial Console:
Blue Note: When sending serial commands the existent code expects the CR & LF to end a line
Red Note: 57600 bps is intentional ! All micro-controllers have different clocks, when working with serial communications both sides (RX / TX) agree on a specific BaudRate / Clock, unfortunately 115200 bps @ atmega328 is not 115200. So let's use 57600.
more here: https://arduino.stackexchange.com/questions/296/how-high-of-a-baud-rate-can-i-go-without-errors
The arduino code (relevant part)
SerialCommand cmd_read_analog_("READ_ANALOG", cmd_read_analog);
SerialCommand cmd_set_led_("SET_LED", cmd_set_led);
SerialCommand cmd_start_push_("START_PUSH", cmd_start_push);
SerialCommand cmd_stop_push_("STOP_PUSH", cmd_stop_push);
accepts the following commands: READ_ANALOG, SET_LED, START_PUSH, STOP_PUSH
some examples:
//reads analog port 0
READ_ANALOG 0
//read analog port 1
READ_ANALOG 1
//read analog port 2
READ_ANALOG 2
//set red led (ON) RGB Led (Common Cathod/255-Off, 0-ON)
SET_LED 0 red
//set red and green led (OFF)
SET_LED 255 red green
//set red and blue led (HALF bright)
SET_LED 128 red blue
//request ping push messages every 1000 ms
START_PUSH 0 1000
//request analog push messages every 3000 ms
START_PUSH 1 3000
//stop ping push messages
STOP_PUSH 0
//stop analog push messages
STOP_PUSH 1
The above commands are examples how:
  1. Set actions (SET_LED) (Note: multiple parameters example)
  2. Read Values (READ_ANALOG)
  3. Monitoring values / Pushing results (START_PUSH / STOP_PUSH)
After submitting the above commands:
Note: After the START_PUSH the arduino code starts pushing messages to the console. This can be modified to instruct the Arduino to perform some action or monitor a sensor and report the values back with a specific frequency or a specific trigger, all depends the code logic.
ARC Side
To be continued...
