Midi Control icon Midi Control — MIDI I/O for ARC: send/receive notes, run per-note scripts, control PC or external instruments, with panic to stop stuck notes. Try it →
Scripting - How To Start/Stop Camera?
I'm looking through all the camera control options in ARC and once I manually start the camera I can control the modes - all that works fine, the functions work great, the examples in ARC work.
What I can't figure out is how to stop/start the camera feed. Does anyone know if that is even an option?
When editing a script, press the Cheat Sheet tab. The available commands are automatically generated for you. You'll find the camera start and stop in the list. Press the command and it will add to your code.
@DJSures :D Thank you!:D
In the Examples I must have over looked it several times, I found the Camera Start Stop example. I think what threw me is I could not find the Control under the Cheat Sheet. What I used is this:
#Start
ControlCommand("Camera", CameraStart)
#and for stopping
ControlCommand("Camera", CameraStop)
But the Cheat Sheet from the script help don't show CameraStart or CameraStop
Camera Device CameraServoTrackEnable CameraServoTrackDisable CameraServoTrackToggle CameraMovementTrackEnable CameraMovementTrackDisable CameraMovementTrackToggle CameraServoTrackRelativeEnable CameraServoTrackRelativeDisable CameraServoTrackRelativeToggle CameraSnapshot CameraTweet (Requires additional parameter) CameraViewRealtime CameraViewProcesssed CameraResetQRCode
Camera Recording
CameraRecordToggle CameraRecordStart CameraRecordStop CameraRecordPauseOn CameraRecordPauseOff CameraRecordPauseToggle
Camera Device Tracking Modes
CameraView CameraColorTracking CameraColorTrackingEnable CameraColorTrackingDisable CameraMotionTracking CameraMotionTrackingEnable CameraMotionTrackingDisable CameraFaceTracking CameraFaceTrackingEnable CameraFaceTrackingDisable CameraGlyphTracking CameraGlyphTrackingEnable CameraGlyphTrackingDisable CameraQRCodeTracking CameraQRCodeTrackingEnable CameraQRCodeTrackingDisable CameraCustomTracking CameraCustomTrackingEnable CameraCustomTrackingDisable CameraMultiColorTracking CameraMultiColorTrackingEnable CameraMultiColorTrackingDisable CameraAutoTracking
