Hey all,
Looks like my ping sensor is not working so I need an alternative. I was hoping to use a web cam. Can anyone tell me if possible and how I could trigger a script upon the detection of motion?
Is this even possible with ARC? I'm heading to bed soon, but the competition is tomorrow so I hope to have this fixed in the morning. Judging is at 1pm.
You can see some progress here:
Thanks for your help! -DaMan
Press CONFIG on the camera control. Select the SCRIPTS tab. You can now edit the Found and Lost script section to execute.
Enjoy!
Thanks for the quick reply DJ. Pardon my ignorance, but is there some documentation that describes how these controls work?
I have Tracking Start: controlcommand("Rat", scriptstart)
Number of frames is 2 (started at 8)
I toggle on motion tracking and then move, it tracks me, but the script does not start....
hmmm
I also just tried moving all of my scripts to a scriptmanager so I could use the syntax in the help tab.
Set both Tracking Start and Tracking End to: ControlCommand( "Script Manager", ScriptStart, "Rat" )
no luck
You will have to enable motion detection under the Tracking tab
Ah.... Using the examples I was able to determine that my syntax was fine. Restarted ARC and VOILA! Works like a charm now!
Thanks DJ!
