Websocket Client icon Websocket Client — WebSocket client for ARC: open/send messages, store server responses in a variable, run a response script, and track connection status. Try it →
Saying A Variable From The Variable Watcher
Ok I am running one of those other boards and sending a variable to EZB and into the variable watcher. This is a room temperature reading. The variable name is $Temp. I want to have EZB tell me the variable value at the time I ask for it. (Example: It is 74 degrees in the room at the time of the reading.) I have tried ... SayWait("The temperature is ", +$Temp) but all i get is a error.
What is the proper way to ask EZB to say a int variable from the variable watcher?
Thanks
I don't think the + or you need a space
  1. you don't interact a variable from the variable watcher. The variable watcher merely displays the contents of declared variables
  2. the syntax to combine variables is the same in all programming languages, which is a + symbol
Your code would be:
SayWait("The temperature is " + $Temp)
I needed to have the space between the "+" & "$Temp".
Thanks guys
And you should not have a comma
