Resolved Resolved by Nomad 6R!
Roli Rolling To The Left
I got my new Roli up and running Sunday, but after a bit, when driving forward it began pulling left and seemed somewhat slower. In reverse, it goes straight and is noticeably faster. Has anyone else had this happen? I was driving it and had done a 180 degree turn just before the veer started.
Roli is not continuous rotation servos, it is motors and an H-bridge controller. If one of your motors is 75% off and only in one direction, it could be a bad motor or H-bridge, or possibly binding on something. How comfortable are you with taking things apart? I would swap the left and right motor connections on the H-bridge to see if the problem follows the H-bridge ports (could also swap the forward and reverse connections on the H-bridge, similar reasoning. See if the motor or the H-bridge is the issue). Could also remove the motors and bench test them with direct battery connections to eliminate any binding in the body and verify if there is a motor problem.
Might want to reach out through the Contact Us page, or during the week day see if James (customer service) is online to chat to see how much troubleshooting you should do before determining it is a warranty issue, but that much difference in speed is certainly a problem. If it was only 5-10% it would just be normal variation, but 75% and only in one direction is certainly not acceptable variation.
What Nomad is suggesting is that perhaps one of the treads is too loose or too tight. He is showing how to adjust the tension. Taking the treads off and seeing if the wheels spin at different rates would tell you if this is the issue.
Also, make sure the treads are not just slipping on the slow side. This can be fixed by tightening the tread, as Nomad shows, or wrapping the wheel in friction tape (available in the electrical section of any hardware store).
that is correct alan,you can see the two screws,if they in line as in pic. you can look further.you can also clean the wheels with little alcohol, also the rubber inside.
Found the issue thanks to the both of you; when I took the treads off, the left front wheel is binding badly. When it goes into reverse, since the drive wheels are at the rear, they were able to overcome the drag. I'll have to get my mini Allen wrenches from work to take off the wheel. Thanks for the help Nomad an Techguru!
Creekdog
can you post if this solution has worked for you.would be a good topic to , ad in the tutorial lessons.
