BN-880 GPS Compass icon BN-880 GPS Compass — Standalone autonomous navigation using Beitian BN-880 GPS/Compass with real-time map waypointing and offline map caching; requires Arduino. Try it →
Resolved Resolved by Rich!
Roli Not Moving
Roli Not Moving
received roli the other day. went through the following steps:
  1. unpacked everything and laid out on table.
  2. verified all parts ordered were received and set up charging since it was a no brainer
  3. opened up ez software
  4. noticed there was "getting started tutorial" link, clicked
  5. started tutorial from here in the roli (https://synthiam.com/Tutorials/) 5a. Did not find tutorial very intuitive as it did not explain how to assemble roli
  6. went back to ez software, click "example projects" link
  7. clicked roli example
  8. asks me if i want assembly instructions, click yes
  9. start through instructions
  10. all built as per instructions 10a. no mention of "red and black" wires left dangling
  11. all assembled plug in charger under roli, light goes green
  12. turn on roli, scares me with loud voice.....
  13. notice there is arrow buttons for moving robot
  14. hold up robot and click the forward button
  15. no movement
  16. notice "connect" buttons in "connection dialog" click top one
  17. pop up asks me to see "getting started" tutorials, click yes
  18. follow instructions and "connect" to roli, says i successfully connected to roli
  19. try movement buttons again, no movement, just buzzing
  20. go back to website, click "connecting H-Bridge"
  21. much better pictures than instructions in ez software
  22. verify my connections are same as pics
  23. notice the "red and black" dangling wires are shown as connected in this tutorial
  24. connect as shown
  25. try clicking movement buttons, no movement, smoke....stress
  26. shut down roli
  27. go to website and do most tutorials, also maintenance/care tutorials
  28. turn on roli, connect, try movement, nothing
  29. search forums for similar problems, found @stephenhoey has similar issue (https://synthiam.com/Community/Questions/6809)
  30. decide to not hijack his thread and start my own
i hope this helps someone help me. i will be taking the roli apart and posting pics shortly.
Try and correct the cable and see if it works. If it doesn't then contact EZ-Robot through the Contact Us page and provide a link to this topic, it may be covered under warranty if it was incorrectly assembled before delivery (you will need to ask them though as I do not know the warranty terms nor can I speak for EZ-Robot)
i am pretty sure that chip is burnt. i will contact ez and it should be covered since i did not wire that part and followed their instructions.
i changed the wire as per the other thread and still absolutely nothing for movement.
thanks for all the help
If EZ-Robot says it will take more than 2 or 3 days to replace the H-Bridge, email me (address in my profile). I have a spare one I don't need for a while. I'll mail you mine, you can have EZ-Robot send your replacement to me.
i'm not sure which is the H-Bridge. is it the one inside the roli (where all the power comes in, with the burnt chip) or the thing in the top that snaps in to the roli?
how much is an H-Bridge normally?
It is the thing inside with the burnt chip. The thing that goes in the top is the EZ-B.
The H-Bridge is just $15 from EZ-Robot, but the shipping is a killer. However since it burned out by being wired wrong, they should replace it for you.
It is not proprietary to them, so if you want to buy one from somewhere instead or waiting on a warranty replacement with lower shipping cost or a Canadian distributor, that is possible.
Note, when I offered to send mine I didn't realize you were in Canada. I might not save any time since it is not the shipping time but the customs hold that usually takes the longest (I am in the US).
The first or third would work. The layout is a little different so it won't be a perfect fit inside Roli, but it should work.
I am sure EZ-Robot will consider this a warranty repair though, and you won't be waiting a year like you did for Roli, just might take a few days or a week to get the replacement to you. Reach out through the Contact Us page. I am sure they will get back to you Monday.
