3-In-1 IMU icon 3-In-1 IMU — EZ-Robot 3-in-1 IMU driver: accelerometer, gyroscope and compass support for motion sensing, orientation tracking and heading/navigation. Try it →
Unknown Country
Robot Connection Issues on Network
Robot Connection Issues On Network
Hello,
When I connect directly to my robot's head, I have full access to functionalities such as scripting and the camera. However, I've noticed an issue when attempting to connect to the robot on the same network after setting it up on my home network to access internet-enabled features. Certain features, like the camera, do not activate. Below is the error message I've encountered:
Camera Initialized: EZB://192.168.1.215 @ 320x240
EZ-B v4 Camera Error: Client disconnected
Camera Disabled
Additionally, the robot is unresponsive to scripts, even though all other features, such as voice recognition, work fine.
Has anyone experienced similar issues or have suggestions on how to resolve this?
EZ-Inmoov Robot Head by EZ-Robot & Gael Langevin
EZ-InMoov Robot Head with Synthiam ARCx: face tracking, speech recognition, Talk Servo jaw motion and AI conversation
Servos 8
ADC 2
Digital 8
Diagnose EZ-B Wi-Fi connection issues with verbose EZ-B communication logging, ping tests, log export and diagnostic reports for Synthiam support.
Below are some troubleshooting steps and ideas to help resolve the issue where the camera and scripts become unresponsive when you connect over your network:
  1. Check Your Network Configuration
    Verify that your EZ-InMoov head (and its EZ-B) has a stable, static IP address on your home network. A dynamic IP change might cause connection interruptions.
    Make sure that no firewall settings on your router or PC are blocking the designated camera ports used by ARC.
  2. Review EZ-B Firmware & ARC Version
    Ensure that your EZ-B firmware is up to date. Firmware updates can resolve connectivity issues that appear only over a network.
    Likewise, confirm you’re running the latest version of ARC, as newer releases often include improvements in network handling for skills such as the Camera and scripting.
  3. Camera Skill Settings within ARC
    When you connect directly (e.g. via USB or a direct connection to the head) the camera initializes normally. In your network setup, the error messages-"Client disconnected" and "Camera Disabled"-suggest the streaming service may be interrupted.
    Try lowering the camera’s resolution (e.g. from 320x240 to a lower value) in the skill’s configuration to see if it improves stability on the network.
    Double-check the camera’s configuration settings (via the gear icon on the control) to ensure that the network interface is selected correctly.
  4. Script Responsiveness Issues
    Since voice recognition still works but scripts become unresponsive, it may be that a script is waiting on an event (perhaps tied to the camera skill) that isn’t firing when there’s a network disconnect. Look through any scripts to see if they include wait conditions or depend on input from the camera.
    If possible, try disabling the camera temporarily in your ARC project and see if your scripts (and related control commands) become responsive again. This can help narrow down whether the camera skill "hangs" the system.
  5. Connection Diagnostic Skill Log
    Review the logs generated by the Connection Diagnostic skill carefully. They might reveal intermittent disconnects or packet loss that are affecting the camera feed.
    Sometimes additional latency on a WiFi network (or mismatches between the EZ-B’s IP settings and your network configuration) can cause the client to drop the connection.
  6. Other Considerations
    If your EZ-InMoov head was initially configured for a direct connection, switching to a networked environment sometimes requires a "reset" of network settings. Try restarting both your router and the EZ-B.
    Test your network performance with another device if possible. A weak WiFi signal or network congestion may cause sporadic disconnections.
Have you noticed if this happens consistently and only over the network? Also, are you using any special network configurations (such as multiple subnets or VPNs) that might affect direct device communication?
By following these steps, you should be able to isolate whether it’s a network configuration, firmware, or project setup issue. Let me know what you find or if you have any additional questions-I’d be happy to dive deeper into any part of your setup.
For more details on network connectivity and troubleshooting, you can always check our support pages at Synthiam Support.
#2   — Edited
Your camera requires the correct address for the ezb on your network. Update the address correctly and save the project. Saving will save the settings. The camera would use the same address as your ezb because your camera is connected to the ezb.
Unknown Country
I figured it out! I had to enable "Camera Transmit Nagle" the advanced network settings of IoTiny
Thanks DJ Sures!
Oh that's great to hear! I would not have thought of that.
