Vertical Servo icon Vertical Servo — Drag vertically to control a servo within set min/max limits; center, release, invert, and mirror to other servos. For 3-wire GVS servos. Try it →
Rgb Animator Display Scripts Work In ARC Pc But Not In Phone Mobile App -
Hello,
I have two buttons in the mobile app that are programmed to run an RGB Animator Display (one button) and to clear the RGB Animator Display (2nd Button). Both of these worked in the mobile app on my Android phone before upgrading ARC. Here is the script code associated with the buttons:
ControlCommand("RGB Animator",AutoPositionAction, "RicksAnimation1") Sleep(300)
ControlCommand("RGB Animator", AutoPositionAction, "Clear RGB Display") Sleep(300)
These commands work in the PC ARC and PC ARC Mobile App Creator. They don't work any longer in the phone app. Again they used to work. Any help would be much appreciated. I have the lattest ARC version installed.
Thanks Much for your help ! Rick
Apologies I haven't had a moment to look at your project yet:)
Hello DJ,
Here are two files you can look at in the cloud:
Latest - Adventure_Robot.ezb2.EZB Earlier Version - AdventureBot1.ezb
Everything works fine in the Mobile App except anything having to do with the RGB Animator Display Control with the current version of PC ARC Mobile Control. Something appears to be wrong with the current ARC RGB Animator Display Control? Thanks again for all your help !:):)
DJ,
I tried making a new project with just the basics. I have two buttons on it and the camera view and uploaded it to the cloud and ran it on my mobile device. Everything worked again except the RGB Animator Control. I also tried using the RGB Animator Display in Scratch and when it got to the RGB Animator Block it didn't highlight it yellow and went right over it to the next step with no display on the RGB Animator Display. Seems to work o.k. in ARC on the PC. Hope this helps in your analysis. Looking forward to hear what you find out !
Is it possible you broke something with the RGB Animator Display when you created the software for the new 8X8 display you have been working on?
Thanks Again for all your help as always ! Rick B. :):)
Use the latest ARC Mobile Android update and you're issue is resolved:)
Hello DJ,
Did you put a new android app in the store very recently? I loaded the android EZ- Builder app on my wife's phone yesterday morning thinking it was my phone, but didn't work either. You must of put a new version of app in app store a few hours ago? Is it the ARC App in the Android App Store? I would assume so. Thanks for your reply ! Rick :)
Hello DJ,
I uninstalled ARC on phone as it said I didn't have enough memory to update it. I deleted some programs I don't use and have 277 megabyte free now and it says I don't have enough memory again to load ARC. How big is the new app? Thanks again. Rick :)
#15
It reads 25,282 KB file size. It should certainly not be 277 megabytes.
I know that Android is a little strange regarding where the Apps are installed (storage vs internal). Can you verify that there is enough internal memory available, and not just storage?
Because not all Android UI's are the same, i'm not certain where to look on your device. Android gives me a headache some times:D
#16
I have seen this before (other apps, not ARC). Often a reboot, or clearing the Google Play Cache will resolve it an allow the app to install.
For what it is worth, I had no issues upgrading to the latest on my Galaxy 6 Edge (Android 6.01).
