Exosphere icon Exosphere — Telepresence and remote control for any robot with human-assisted tasks, video, audio, and AI training via ARC and mobile devices Try it →
Rgb Animator Display Scripts Work In ARC Pc But Not In Phone Mobile App -
Hello,
I have two buttons in the mobile app that are programmed to run an RGB Animator Display (one button) and to clear the RGB Animator Display (2nd Button). Both of these worked in the mobile app on my Android phone before upgrading ARC. Here is the script code associated with the buttons:
ControlCommand("RGB Animator",AutoPositionAction, "RicksAnimation1") Sleep(300)
ControlCommand("RGB Animator", AutoPositionAction, "Clear RGB Display") Sleep(300)
These commands work in the PC ARC and PC ARC Mobile App Creator. They don't work any longer in the phone app. Again they used to work. Any help would be much appreciated. I have the lattest ARC version installed.
Thanks Much for your help ! Rick
Verify the project is the same on the cloud as on your PC.
Hi DJ,
Would I do this by loading the project from the cloud back to the PC? Would this be done from the PC ARC menu bar ? Is it just the mobile app that we are comparing? Thanks Much ! Rick:)
Yeah - exactly.
Also, if your project is public, I can test it for you tonight. Otherwise if it isn't public, provide me the ezcloud filename and I will test it tonight as well.
Thanks DJ,
I will make it public and also let you know what the file name is. Thanks again. Rick:)
Hello DJ
I decided to not make the app public at this time. I have some IP addresses and username and passwords in some of the scripts.
I did check the cloud version compared to the version on my laptop and they appear to be exactly the same.
The file that you can check is: AdventureBot1.ezb
It is looking to me like there is a problem with the RGB Animator Display Control in the latest versions of the ARC PC Mobile App Creator? Only a guess and probably not correct but will be interested to see what you find.
Thanks for checking this out for me. I am at a loss at the moment as the RGB Animator Display buttons worked fine in the mobile app in previous versions of ARC. Rick :)
Thanks! I'll take a look tonight - I'm in San Francisco for the next few days and won't be at the hotel until this evening
Hi DJ,
Just wondering if you had a chance to check out my AdventureBot1.ezb file in the lattest version of ARC. Interested in seeing if RGB Animator Display works in Mobile App on phone. Also you might try looking at history file for this file and maybe load an earlier version that uses an earlier version of ARC. I could do this also, but didn't want to load to the cloud until you have a chance to check it out first. Thanks Much DJ ! Rick B. :)
DJ,
I went to the cloud and downloaded a previous version of my file AdventureBot1.ezb that I know worked and the RGB Animation Display buttons don't work.
When downloading a previous version of the file from the history section of the file name, does it load the PC ARC version that the file was created in or does it download the file into the current latest version of the ARC Software that is installed on ones PC or Laptop?
If it loads the previous version (selected from history files) of AdventureBot1.ezb into the current version of ARC that is installed on my Laptop then it does point I think, to something broken in the RGB Animator Display Control for the Mobile App.
With the latest version of ARC downloaded on the computer I can go to the mobile app creator and activate the Animation Display button and the Clear Animation Display buttons and they work fine. When I upload the app to the cloud using current ARC version and download it to my Android Phone these two buttons for the animator do not work. Again they used to work.
Looking forward to hearing your thoughts on this issue? Thank again for all your help. Hope your trip to San Francisco was successful ! Rick B.:)
