Personality Generator icon Personality Generator — Background randomizer that executes timed scripts to add lifelike actions (movement, servos, camera/control) and unique personality to your robot Try it →
I will. What does it do?
Thanks for the help.
@Ellis,
Allows you to configure the Windows SAPI (Speech Api) settings, API used by ARC software.
Did you tried ? Any progress ?
Actually I added a second WiFi dongle as recommended and everything started work correctly :):). I will have to keep testing to see if it continues to work.
Yes I did what you recommended. It turned out to be the same Windows configuration window that I have tried in the past. I did it again and it didn't work. Later after getting the second WiFi to work it began working. I think their was some conflict that was causing it not to work. I know it doesn't make sense but that is what happened. At least now I know it can work right.
Thank you so much for being patient and working with me on this. I really do appreciate your ideas.
