Hello
is an easy way to Kinect Relay Module to EZ-B
Roll Pitch Yaw
— Rotate and position camera or object with roll/pitch/yaw controls; save camera settings; bind or monitor a 3-value EZ-Script array for live rotation.
Hello
Did you mean "Is there an easy way to connect a relay module to the EZ-B"?
If so then yes. Look for Josh's Saltwater Tank project, he has used some relays on that. From memory he used a TIP transistor circuit to energise the relay.
Or you can simply buy a ready made module that is opto-coupled and isolated. You may connect it to any digital output from EZB
Module with 2 relays
