Key Control icon Key Control — Assign scripts to any keyboard key (press/release), map arrow keys to movement controls; activates when the control has focus (green). Try it →
Did you mean "Is there an easy way to connect a relay module to the EZ-B"?
If so then yes. Look for Josh's Saltwater Tank project, he has used some relays on that. From memory he used a TIP transistor circuit to energise the relay.
United Arab Emr
Or you can simply buy a ready made module that is opto-coupled and isolated. You may connect it to any digital output from EZB
Module with 2 relays
