Servo Script icon Servo Script — Bind scripts to servo moves (V1-V99); triggers on position/speed/accel changes and provides ports, positions and speeds arrays for custom control. Try it →
Check your connections and see if they are similar to these images:
@Robot-Doc I'm glad you did that as I just tried but my phone is useless...
@Robot-Doc , @Rich , the following component in my camera broke... I observed it just now... Is there any way I can replace it or is it a good bye to my camera?
There are only two leads on that device, with the proper soldering iron and tip (and possibly a magnifier lens) that should be repairable.
I would like to know what are leads? I mean can I buy them? Do we have any rating for that? Coz there is not even little gap for it to be soldered..
Look around for some resistors or capacitors with leads on the ends, possibly in your parts drawer. Most are 24 to 26 gauge wire. You just want to splice a short piece that you cut off and solder.
Also a picture would help us see what damage you are actually dealing with.
#15
Yeah here are the images... If you need much clear ones I'll click them...
That appears to have a designation of Y1 and it has two leads so it is probably a crystal. Problem is on my camera I don't see any printing on the metal can so I don't know the frequency.
