Midi Control icon Midi Control — MIDI I/O for ARC: send/receive notes, run per-note scripts, control PC or external instruments, with panic to stop stuck notes. Try it →
Red light means it is charging. Have you removed the battery from the camera? If not I'd suggest doing so.
Also, if it's getting hot check for shorts between vcc and ground.
okay... I don't have a battery for the camera.. We power it through EZ-B...
Check for shorts in that case.
Externally when I check the wiring.. There is no short... But when I'm checking it with a multimeter... I found there is a short... What might be the reason?
I checked the circuit and resoldered it again.. But there is no short externally.. But the multimeter shows a short... stress
Some one please help me out... I should exhibit my robot tomorrow... stress stress stress
There is a short between all the three Vcc GND and Signal...:(:(:(
pic of your wiring?
Without seeing pictures of both sides of the camera board we can't really advise on what it is likely to be.
To confirm (as I just double checked) there should be an open circuit between all 3 pins of the cable going to the EZ-B.
