It has been said that the EZB4's middle bus will have whatever VCC that you supply it. But, will the little 5v two pin connector still be there?
Thanks,
Read Digital
— Read TTL digital input from an ARC I/O port; real-time red/green status for low (0V) or high (+3.3/5V), selectable board/port and read interval.
Thanks,
It does not appear to be there.
Thank You for the Reply. I just need to power my sabertooth with an additional +5v, I think.
If you put a 5v regulator from either your ez-b or your battery it could work.
Why do you need to power your sabertooth with 5V? It's input voltage is whatever your motor needs are .... from about 6 - 24 volts.... It gets it's power from the battery you plug into it... The sabertooth can't run anything off of 5V...You only need 2 wires from the ezb.... Signal wire to S1 of the sabertooth and the ground wire... It does however, have a 5V bec to power other devices like a radio receiver.... You really should download the manual and have a read.... before possibly wiring it wrong and ruining it....
Richard, now that you point that out...
MOVIE MAKER! Don't wire the 5 volts from the sabertooth to your ez-b port!
Like Richard said, all you need the the signal cable to s1 on the saber and the ground.
Nice catch Richard.
Thank You Both so much.
