Watson Speech To Text icon Watson Speech To Text — Watson Speech-to-Text ARC plugin: cloud AI transcription with configurable models, selectable VAD (Windows/WebRTC), audio capture and visualization. Try it →
Question About Servomotors And Clip´n Play Arms
Question About Servomotors And Clip´N Play Arms
Hello, I have printed the arm pieces for the hexapod robot, but Ive found a problem: the servo has supports in both sides (as shown in figure). Is it necessary to cut one of them to make the arm work fine? I cant find any information about how is the correct way to assembly of this part. Thanks for the help. stress
Good question. All of the pictures look like the servos they are using have no top brackets.
Some people get special brackets and take the assembly out of the case and put it in the brackets.
You have to cut one of the brackets:) Use a pair of side cutters and clip the bracket on the side with the wire:)
