Soundboard (EZB) icon Soundboard (EZB) — Play WAV/MP3 via EZ-B v4, manage tracks, add timed scripts for synced robot actions, control via ControlCommand(), volume and clipping indicators. Try it →
Powering H-Bridge And 12V Dc Motors And Feedback Pots
My next project is a BB-9. If anyone knows of it, I'm using the Joe Drive and 12v DC Planetary Motors with BTS7960 43A High Power Motor Driver H-Bridges. I'm using a 12V 20000mah battery for power.
If I power the EZ-b with 12v, can I run the power from the digital port straight to the H-bridge, or should I power it from the power source?
Thanks
@kashyyyk,
If you are using a power base, there is a 20 amp fuse
Fuse Replacement Lesson: https://synthiam.com/Community/Tutorials/47
If both motors pull more than 20 amp, you will end-up replacing the fuse.
There are other issues like wire gauges, you need to have proper wires to handle the motor amps.
My recommendation is to have separate circuits EZ-B and motor h-bridges.
you need to pickup the right wire gauge, and a fuse block something like this:
https://www.superdroidrobots.com/shop/item.aspx/atc-blade-fuse-block-4-circuit/1837/
The supply voltage for your motors pulling up to 43 amps should be supplied from a power source capable of supplying the peak 43 amps needed. Do not channel this amp rating through the EZB. 20 amps total for all devices is recommended. There's a protective fuse that will blow it you exceed this rating. However it looks like the logic part of this h-bride is 3.3-5V. This voltage might be able to be supplied by the EZB directly or channeled through it. ;)
Actually a small correction here. The ezb4 can supply 5 amps continuous through the digital power pins with the occasional current spike of 20 amps... Either way, power your H-bridge directly from a battery or power source... EZB4 specifications PDF
Happy New Year!
Ok thanks! I'll power them through a fuse panel.
Once I get it wired, I know I will have script questions.
@RichardR
Thanks, and i believe can be very relevant.
I missed that point, I wrongly assumed the VIN is connected to the Digital Ports Red Pin.
back to the lesson: https://synthiam.com/Community/Tutorials/163/3
Quote:
The "maximum" continuous current draw through the EZ-B v4, is 5 amps. (limited by reverse polarity protection).
PCB: EZB4:
one Schottky's diode (A7 T35) between the power in and the Vin. The 5 Amps must be diode max forward current.
Iotiny: one Schottky's diode (A7 T63). I'm guessing ... the diode reference is different the limit must be different too.
Once again thanks for pointing out!
