Germany
Polymorph: Which Coloring Substance Is Recommended?
Which coloring powder or other way to color Polymorph do you recommend the most?
Which properties should the colering substance for Polymorph have? For example: Should it be organic or anorganic. Should it be mineralbased...?
Try this stuff...
https://www.mcmelectronics.com/product/21-12865?green=BFE4CF12-93C0-5CE2-0E55-BB2B397794DC
They are little pellets like the polymorph itself. You can drop one pellet in while you're heating the polymorph up. Work the colorant into the polymorph with your hands, then reheat it to shape it. One colorant pellet goes a long way. I used it to make some panels that cover the front openings in my omnibot.
