Getrss icon Getrss — Fetch RSS via GetRSS command; populates $RSSSuccess, $RSSErrorMsg and arrays $RSSTitles, $RSSDescriptions, $RSSLinks, $RSSDates for scripts. Try it →
thats correct i dont see the gear also
The gear icon is in the camera control not the movement panel. If the brookstone rover isn't moving then the issue is with the movement panel, the camera control config wont help.
ah thats good.for excample would it be possible to use robome?
You know what, I just spotted one thing... This topic is about a Rover 2.0
I am not sure that the V2.0 is compatible with ARC... I'll have to search a bit for the answer but everything mentioned is for the V1.0 This may be why there are problems...
yes there was some post telling this.
I can't see where support for the Brookstone Rover V2.0 was added to ARC. I have seen a few topics where it was discussed but there were no mentions of it being added to ARC.
The control help page mentions only the V1 too, no mention of the V2.0 being compatible.
I also read an old post by DJ where he explained that adding third party robots is not high priority.
Therefore I would say that the Brookstone Rover V2.0 is not compatible with ARC. Which would explain the problems with controlling it.
#15
ok but then how come the camera moved when i clicked connecf?
all 4 are correct. in the video tutorial was earlier a link whit the correct rover that worked.but the link is no more there. some will work others dont.
