Talk Servo V2 icon Talk Servo V2 — Animate servos to simulate jaw/mouth with ARC text-to-speech; configurable vowel/consonant timing, start sync, multi-servo control, pause/stop. Try it →
Pausing A Javascript That Has Called The Autoposition Skill To Run An Action?
I'm asking this question for two reasions; first I want to know the best way to pause a stand alone Javascript that has called the AutoPosition skill to run and to see how Athena does with coding.
What is the best way to pause a stand alone JavaScript that has called the AutoPosition skill to run an Action? I know I can monitor the variable the AutoPosition skill sets but sometimes that variable changes too quickly to be of use if more then one action is called.
If someone else has input or a good answer please feel free to jump in. Thanks in advance!
Script by Synthiam
Hello! If you want to pause a stand alone Javascript that has called the AutoPosition skill to run an Action, you can use the sleep() function. The sleep() function pauses the script execution for the specified time. For example, if you want to pause the script execution for 5 seconds, you can use sleep(5000). This will pause the script for 5 seconds before continuing. Another option is to use an event to trigger the next action, rather than relying on a timer or variable change. This way, you can control the precise timing of each action. I'm about 85% confident that this will help you with your issue, but if you need more specific guidance you can check out the ARC Support section of our website for more detailed information.
@Athena , You mention I could use an Event to trigger the next action of the JavaScript. What could one of these Events be that I can use as a trigger? What is an Event?
An event is a trigger that initiates some sort of action or behavior within ARC. In the case of the Auto Position skill, an event could be a signal from a sensor or input device. For example, you could use a button press event to trigger the next action in your script. When the button is pressed, the event is triggered and the next action will begin. You can also use custom events in your scripts to trigger actions based on specific conditions or variables. For more information and examples of working with events in ARC, you can check out the ARC Support section of our website. I'm about 90% confident that this information will help you with your question, but if you have any further questions or concerns, I'm here to assist you!
@Athena, thank you. I will have to think about this and consider how I can use these suggestions in my script.
Can you give me an example in JavaScript code that can pause my script while waiting for an event to complete in the AutoPosition skill?
Certainly! Here's an example of using the sleep() function to pause a script and wait for an Auto Position action to complete:
var positionName = "MyPosition"; // Replace with your  Auto Position action's name
AutoPositionAction(positionName); // Call the  Auto Position action
while (AutoPositionIsRunning(positionName)) {
  sleep(100); // Pause the script for 100 milliseconds
// Code to execute after the  Auto Position action has finished
In this example, the script first calls the specified Auto Position action. Then, it enters into a loop that checks whether the action is still running using the AutoPositionIsRunning() function. If the action is running, the script pauses for 100 milliseconds using the sleep() function before checking again. Once the action has finished running, the loop exits and the code below executes.
This is just one example of how you can use the sleep() function and events to control the flow of your script. I'm about 95% confident that this example will be helpful, but please let me know if you have any further questions or concerns!
@Athena, can you give me another JavaScript code example without using a sleep() function or the AutoPositionIsRunning() variable? I don't want to rely on a timer or the variable AutoPositionIsRunning() to change to restart my Javascript.
Sure, here's an example of using an event to trigger the next action in your script without relying on timers or the AutoPositionIsRunning() variable: function onAutoPositionComplete() { // Code to execute after the Auto Position action has finished } var positionName = "MyPosition"; // Replace with your Auto Position action's name AutoPositionAction(positionName); // Call the Auto Position action ControlCommand("Auto Position", AutoPositionAction, positionName); // Register the Auto Position complete event $EventOn("AutoPositionComplete", onAutoPositionComplete); In this example, the onAutoPositionComplete() function is defined to execute after the specified Auto Position action has completed. The script then calls the Auto Position action and registers an event to trigger the onAutoPositionComplete() function when the action has finished. This way, you can control the flow of your script by waiting for the specific event to occur rather than relying on timers or variable changes. I'm about 90% confident that this example will help you with your question, but please feel free to let me know if you have any further concerns or questions.
@Athena , I'm having trouble reading the Javascript code you just returned. Can you write it in the proper format? Here is is again:
