XV Lidar Bridge icon XV Lidar Bridge — Neato XV LIDAR integration for ARC with live radar, 8-zone obstacle detection, NMS support, calibration, and scan watchdog monitoring Try it →
Passing variables between Javascript and EzScript.
Passing Variables Between Javascript And Ezscript.
Prior to ARC, I was able to pass variable among different scripts using EzScript.  I can still do that, but I cant pass a variable in JavaScript to and Ezscript.  is that something that can be implemented?
JD Humanoid by EZ-Robot
getVar( variableName, [default value] ) Retrieves the value from the Arc’s global variable storage. These are variables that are published by skill controls, such as the Camera, Auto Position, Speech Recognition, etc..
- The name of the global variable as a string - [Optional] If specified, this value is returned if the global variable doesn’t exist. - The value of the global variable
Example: // Get the current direction the robot is moving var direction = getVar("$Direction");
// Get the value of $test, and if it doesn’t exist return false var testVar = getVar("$test", false);
setVar( variableName, value ) Sets the value from of Arc’s global variable storage. This allows the variable to be available to other controls or other scripts by using getVar().
- The name of the global variable as a string - The value that you wish to store in the global variable - The value of the global variable
Example: // Set a value of 5 to be accessible by other controls setVar("$MyValue", 5);
varExists( variableName ) Check if the global variable exists.
- The name of the global variable as a string - true/false Boolean if the variable exists
Example: // print if the variable exists print(varExists("$MyValue"));
Dang it.  I didn't read that, as you've probably figured out.
So it worked, it set the variable, I can see it in the variable watcher.  But my ez script doesn't see that the variable has a value.  This script was wrote in a couple of versions before ARC.  Does that matter?
#3   — Edited
Perhaps you're trying to read the variable in EZ-Script before it is being set by Javascript. One exists only when one is existing:D yoda says
Javascript set the variable..
setVar("$myVariable", "this is text");
EZ-Script print the contents of the variable
print($myVariable)
It was working all the time.  My old ezscript had an error and instead of halting, it just ran and did nothing.
but I found it and marked this resolved.
Thanks for the help, good night.
Anytime:) have a great night as well!
