Rafiki Front Bumber icon Rafiki Front Bumber — Rafiki front bumper plugin: reads 4 proximity sensors via serial, updates ARC variables, blocks motor movement toward detected obstacles for SLAM Try it →
One Board Connects To Wifi But Won't Get An Ip Address
Hello everybody!
Just checking if I may be able to fix this issue otherwise than by changing the main board to my main robot.
This robot has 2 V4 boards (+ 1 V3 that serves only to put everything on standby by controlling a simple relay).
One of the 2 V4 boards will simply not be able to get a stable IP address. Since I use 2 DHCP routers which serve onto the same subnet (but different range of addresses) in order to handle all my devices (40...), I first thought there was some mess with my network configuration so, before I left to Europe for 2 weeks, on Monday I tried pretty much everything, as far as connecting the board to a lone router, totally separated from my network. I reset the board's settings several times, AP mode will work, although not very stable, ARC would lose connection fast and I'd have to power cycle the board each time. This is actually what the first symptoms back when client mode would work : it would disconnect and require power cycling to reconnect, until it would not get any IP at all, although I hear the successful connection audio message, each time.
Let me know if this has happened to any of you and if you found out what caused it. The only thing I didn't try is disconnecting all wires because last time I did that it took me far too long to reconnect everything so this would be a last resort solution, and I'd probably change the board.
It is really weird: successful connection in client mode to the router, but no IP and the router, would actually see its mac address without being able to assign an IP (which can be seen in the mac filter list).
Best regards, Elfège.
ok, all probs solved thanks to firmware flash. Thanks a lot everybody!
@Elfege,
Are you using the custom firmware ?
I'm located in New Jersey, sometimes i commute to NYC, if anyone needs help flashing ping me here.
Hi Ptp! Ans thanks so much for this firmware. I'm using the one you posted in a thread to which I had been redirected by Dj.
Do you have iMessage? If so text me to my email address which is my first name at my first name dot come (elfege is my real first name)
And if not just email me and I'll send u my phone number so we can chat over a drink some day. You may also find me on fb
Cheers.
