EZB Connection icon EZB Connection — Connects EZ-B I/O controllers to ARC via COM or IP (5 connections). Supports init scripts, battery monitoring, TCP/EZ-Script server and serial/I2C. Try it →
aameralis, do you have a spare right arm of an Omnibot 2000 I could purchase from you, I need the gears, shoulder, wrist gear, and rubber fingers (I only have three rubber fingers total). If not that's ok, Thanks.
Anything will help. I have both arms, but I want to put gears in the left arm and have it move like the right one. Thank you again, you are the best!
Germany
Any news on the printed Omnibot 2000 rubber treads? Ninjaflex should do the trick. @ Anthony: do your treads have the parts that connect/insert the treads to the wheel (base) inside? I am thinking about getting a 3D scan of the treads to have them printed. What do you think?
@Anthony I would love to order a set of these printed treads...are they available
