UBTECH Alpha Servos UBT-12HC icon UBTECH Alpha Servos UBT-12HC — Control UBTECH Alpha UBT-12HC smart servos via ARC using EZ-B v4/IoTiny UART, assign virtual ports, set baud, custom bits and position mapping. Try it →
all nest features are working correct. Please verify your configuration with the nest website and ensure you have followed the tutorial previously listed. If you have additional information of your Nest configuration or devices, please let us know to see if there's an unusual configuration that is breaking the Nest webservice.
Attached shows the Nest is successfully setup in ARC and the other picture shows ezrobot on my nest account.
removed connection and then readded. Still getting same error.
Hmm...
Can you give me a description of your devices? (carbon sensor, thermostat, camera, etc)
That did it! I have only the Thermostat. I can now run that two line script without an error. Thanks very much.
