TCP Clients icon TCP Clients — Monitor incoming TCP Server connections when TCP Server is enabled under Connection > Config; view and track live connections. Try it →
what processer does it use ? the 40 pin ic
The EZ-B v3 uses a 18F4685 with a custom bootloader and firmware.
thank DJ
Stupid question.... will you be able to do anything with an "empty" 18F4685 chip without ez robots custom firmware? I mean doesn't ez robot have to add something to it before it can accept firmware?
