Wowwee MIP Movement Panel icon Wowwee MIP Movement Panel — UART-based EZ-B/ESP32 skill to control WowWee MIP, enabling ESP32-Cam camera support and flexible battery-powered integration. Try it →
Need 3D Model Of Micro Servo With Metal Gears
I need 3D model of micro servo with metal gears like the ones that came with the humanoid robot. I want to 3D-print dummy micro servos. I don't have the real micro servos. Also, I have problems 3D-printing some robot parts that require supports. Removing the supports leave rough surfaces on robot parts. I don't have the correct filament for supports. I have to go online and order micro servos, RGB LED Block, battery, charger, and filaments. I already ordered EZ-Brain Controller and Camera combo. Any suggestions?
All 3D printable item design files are in the 3D printing menu item right above these posts. Select the components that you want to print and the design files are included.
Oh jeff, you're right - the download for those files are in ARC only (not the wesbsite). Thanks for correcting my reply.
To get the STL files, download ARC from the top menu. You can access the EZ-Bit parts through either the EZ-Robot Designer or Build Instructions of any Revolution robot project.
@jefmorris : No problems here to print all parts. I use simplify 3D, you don't have any issues with the manual or automatic supports. They come off very easy and clean.You don't need an other filament for the support,use the same as the print.
I found out that Autodesk MeshMixer can create customized supports.
Wow, If simplify 3D does what is says then the $150 USD price tag seems well worth it. Looks like 3D printing is getting closer to the user friendly level where I'd jump into it. :)
It does that and much more. I m very pleased with it. In the past used a lot of free software did' get the best results and changed over.
