Multiple Servo Control Using Speech Recognition.
My Current project is a custom made robot for the Children's Museum that has two arms that move, with wrists that turn and two Eyes that open and close.
How do I go about using the speech Recognition commands to operate multipule servos at the same time. For example: I want to say "Robot Blink" and have the two servos that control the iris's to both open and close at the same time. They are connected to D13 and D14 on the EZ-B board.
I also what to be able to do the same with both arms, so it can raise it arms straight up to the side of the robots head when I say the command "Robot arms up"
How do I go about doing this as the scripting commands only allow you do use one servo at a time.
Dan S.
Put the 2 servo commands one after the other, they will run pretty much at the same time.
# Move servos to position 70
Servo(D13,70)
Servo(D14,70)
# Wait 1 second
Sleep(1000)
# Move both servos to position 10
Servo(D13,10)
Servo(D14,10)
To the right of the command line in speech recognition is a small icon of a pencil, click it to open a bigger scripting dialogue.
Rich: do I do this through ARC after I open up the speech recognition contol?
Dan S.
Yes, when I get home I'll pop up some screenshots if you're still stuck
Rich: I think I see what you ment. I think I have it, but will have to test it to see if that is what I needed. I found the pencil you were talking about.
Dan S.
Rich: One other thing, When useing the speech recognition commands, does it always have to start out with "Robot" or can you uses something else. Foe example, this robot is called "Mind Munchie" and they would like it to respond to it's name. So can I use Mind Munchie in place of Robot?
Dan S.
I've not used voice recognition much but I think you can use anything in the box, you probably don't even need the prefix, just "move left" should work.
Rich: never mind on that last question. I found out that I can use Mind Munchie instead of the word Robot to give commands. I have the Winking and Blinking working and working on the script for the arm movement now.
Still need to work on getting the Sparkfun MP3 Trigger to work with voice commands yet, but that should be easy to do.
Dan S.
If you already have the scripts written you can always use the ControlCommand() to have voice recognition start (or stop) those scripts.
