I am trying to use the 4 in 1 sensor from the ezb and get the information in C# through the use of the SDK.
I had hopes that there would be a sample project for this sensor but I couldn't find one. I know you have to first initialize the sensor. Does anyone know the command to initialize the sensor? I assume once it initialized, I will be able to get the bytes that are returned.
Any help would be beneficial.
Thanks! David
I do believe you just have to use the I2C commands : Link.
As for initializing, you want to use the values read at level as offsets to mark what is true zero.
Got it figured out with a port sniffer.
Thanks!
Download the latest EZ-SDK. There is an MPU module class included in the EZ_B namespace.
Sounds good. Thanks DJ.
