Stream All The Video Sources icon Stream All The Video Sources — Stream video from any URI/protocol (RTMP, RTSP, HTTP, UDP, etc.) to a selected ARC camera device for real-time network feed playback. Try it →
Germany
Mono Ezb.connect Not Working
Mono Ezb.Connect Not Working
Hello, i tried to program my EZ Robot with C# under Ubuntu 15.04.
using System; using EZ_B;
public class HelloWorld { public static void Main() { Console.WriteLine("Enter IP of EZ-Robot"); string ip = Console.ReadLine(); Console.WriteLine("IP: "+ip ); Console.WriteLine("trying "+ ip); Console.WriteLine("trying to connect with " +ip);
    //connecting
    EZB _ezb = new EZB();
    _ezb.Connect(ip);
    Console.WriteLine("connecting...");
    if (_ezb.IsConnected)
            Console.WriteLine("[+] EZB connected at ip: " + ip);
            else
            Console.WriteLine("[-] EZB NOT connected at ip: " + ip);
Thats my code, but if i execute it...
patrick@patrick-X781X-X782X:~/ezrobot$ mono bsp.exe Unknown heap type: #GUlD
Unknown heap type: #Blop
Enter IP of EZ-Robot 192.168.1.1 IP: 192.168.1.1 trying 192.168.1.1 trying to connect with 192.168.1.1 Missing method .ctor in assembly /home/patrick/ezrobot/EZ_B.dll, type System.Runtime.CompilerServices.ExtensionAttribute Can't find custom attr constructor image: /home/patrick/ezrobot/EZ_B.dll mtoken: 0x0a00000a
Unhandled Exception: System.TypeLoadException: Could not load type 'System.Runtime.CompilerServices.ExtensionAttribute' from assembly 'EZ_B'. at HelloWorld.Main () [0x00000] in :0 [ERROR] FATAL UNHANDLED EXCEPTION: System.TypeLoadException: Could not load type 'System.Runtime.CompilerServices.ExtensionAttribute' from assembly 'EZ_B'. at HelloWorld.Main () [0x00000] in :0
There must be a mistake with the "ez.Connect" command....
Thanks for help, Patrick.
There is no mistake, as it compiles and runs fine on my test. I would recommend using the universl bot library instead, as it also provides you access to the source code.
My problem is solved:) "EZB _ezb = new EZB();" must stand before void main:D
But now I have this issue:
dmcs -r:EZ_B.dll bsp.cs bsp.cs(16,9): error CS0120: An object reference is required to access non-static member `HelloWorld._ezb' Compilation failed: 1 error(s), 0 warnings
in Line 16 is "_ezb.Connect("192.168.1.1");"
As you can imagine, it's difficult to assist when I only see a small fragment of the project. If you insist on moving forward with the mono library, please post your project or complete code and we'll get you running:)
Are you also using Linux? Which compiler do u use? How do you compile it? Thanks for your time;)
public class HelloWorld { EZB _ezb = new EZB(); //this stands now before ""void main"
//connecting
_ezb.Connect(ip); Console.WriteLine("connecting..."); if (_ezb.IsConnected) { Console.WriteLine("[+] EZB connected at ip: " + ip); } else { Console.WriteLine("[-] EZB NOT connected at ip: " + ip); }
in simple form:
console output:
patrick@patrick-X781X-X782X:~/ezrobot$ dmcs -r:EZ_B.dll bsp.cs bsp.cs(12,9): error CS0120: An object reference is required to access non-static member `HelloWorld._ezb' Compilation failed: 1 error(s), 0 warnings
This is because the MAIN() is declared as static. The error message explains it. It says, an object is required to access a non-static member, and gives you the object, which is _ezb.
An error is written text to explain what the issue is. The error says the object _ezb is non-static but is being called from a static method.
As you can see, the method Main() is static, and the variable ez_b isn't.
Either make the _ezb static, or make Main() not static. I'm not sure if you can make Main() not static, but try and let me know:). Otherwise, make _ezb static.
Here's a document i found for you that discusses the difference between static and non-static declaration: https://www.c-sharpcorner.com/uploadfile/abhikumarvatsa/static-and-non-static-methods-in-C-Sharp/
Thanks for answering,
if i make the main void non static .... public void Main() .....
there is an error: error CS5001: Program bsp.exe' does not contain a static Main' method suitable for an entry point
so I think void main must be static.
Then i tried to make _ezb static:
public class HelloWorld { static EZB _ezb = new EZB();
public static void Main() { Console.Clear(); Console.WriteLine("Enter IP of EZ-Robot"); string ip = Console.ReadLine(); Console.WriteLine("IP: "+ip ); Console.WriteLine("[+] trying "+ ip); Console.WriteLine("[+] trying to connect with " +ip);
//connecting
Console.WriteLine("connecting..."); _ezb.Connect(ip); Console.WriteLine("[+] connecting process finished"); Console.WriteLine("wating for result...");
else { Console.WriteLine("[-] EZB NOT connected at: " + ip); }
it compiled:)
but if I execute it....
patrick@patrick-x781x-x782x:~/ezrobot$ mono bsp.exe Unknown heap type: #GUlD
got wrong token: 0x6d22a7bf
Unhandled Exception: System.TypeInitializationException: An exception was thrown by the type initializer for HelloWorld ---> System.TypeInitializationException: An exception was thrown by the type initializer for EZ_B.EZB ---> System.BadImageFormatException: Bad method token 0x6d22a7bf on image /home/patrick/ezrobot/EZ_B.dll. --- End of inner exception stack trace --- at HelloWorld..cctor () [0x00000] in <filename unknown>:0 --- End of inner exception stack trace --- [ERROR] FATAL UNHANDLED EXCEPTION: System.TypeInitializationException: An exception was thrown by the type initializer for HelloWorld ---> System.TypeInitializationException: An exception was thrown by the type initializer for EZ_B.EZB ---> System.BadImageFormatException: Bad method token 0x6d22a7bf on image /home/patrick/ezrobot/EZ_B.dll. --- End of inner exception stack trace --- at HelloWorld..cctor () [0x00000] in <filename unknown>:0 --- End of inner exception stack trace --- patrick@patrick-x781x-x782x:~/ezrobot$
In Visual Studio under Windows it worked perfectly...
If i get this running, I will make a Tutorial on your Website to help other users:)
