Oculus Quest Robot icon Oculus Quest Robot — Immersive Meta Quest VR control for Synthiam ARC robots: stereoscopic camera view, map servos to hands/controllers, plus built-in remote desktop. Try it →
Germany
Mono Ezb.connect Not Working
Mono Ezb.Connect Not Working
Hello, i tried to program my EZ Robot with C# under Ubuntu 15.04.
using System; using EZ_B;
public class HelloWorld { public static void Main() { Console.WriteLine("Enter IP of EZ-Robot"); string ip = Console.ReadLine(); Console.WriteLine("IP: "+ip ); Console.WriteLine("trying "+ ip); Console.WriteLine("trying to connect with " +ip);
    //connecting
    EZB _ezb = new EZB();
    _ezb.Connect(ip);
    Console.WriteLine("connecting...");
    if (_ezb.IsConnected)
            Console.WriteLine("[+] EZB connected at ip: " + ip);
            else
            Console.WriteLine("[-] EZB NOT connected at ip: " + ip);
Thats my code, but if i execute it...
patrick@patrick-X781X-X782X:~/ezrobot$ mono bsp.exe Unknown heap type: #GUlD
Unknown heap type: #Blop
Enter IP of EZ-Robot 192.168.1.1 IP: 192.168.1.1 trying 192.168.1.1 trying to connect with 192.168.1.1 Missing method .ctor in assembly /home/patrick/ezrobot/EZ_B.dll, type System.Runtime.CompilerServices.ExtensionAttribute Can't find custom attr constructor image: /home/patrick/ezrobot/EZ_B.dll mtoken: 0x0a00000a
Unhandled Exception: System.TypeLoadException: Could not load type 'System.Runtime.CompilerServices.ExtensionAttribute' from assembly 'EZ_B'. at HelloWorld.Main () [0x00000] in :0 [ERROR] FATAL UNHANDLED EXCEPTION: System.TypeLoadException: Could not load type 'System.Runtime.CompilerServices.ExtensionAttribute' from assembly 'EZ_B'. at HelloWorld.Main () [0x00000] in :0
There must be a mistake with the "ez.Connect" command....
Thanks for help, Patrick.
#17
bsp.cs(27,14): error CS1056: Unexpected character `'
bsp.cs(27,21): error CS1056: Unexpected character `'
bsp.cs(27,25): error CS1056: Unexpected character `'
bsp.cs(27,31): error CS1056: Unexpected character `'
bsp.cs(27,31): error CS1525: Unexpected symbol `Fine', expecting `,', `;', or `='
bsp.cs(27,36): error CS1056: Unexpected character `'
bsp.cs(27,42): error CS1056: Unexpected character `'
bsp.cs(27,49): error CS1056: Unexpected character `'
bsp.cs(27,55): error CS1056: Unexpected character `'
bsp.cs(27,60): error CS1056: Unexpected character `'
bsp.cs(27,70): error CS1056: Unexpected character `'
bsp.cs(27,70): error CS1525: Unexpected symbol `5', expecting `,', `;', or `='
#18
with this command
_ezb.Servo.SetServoFineTune(Servo.ServoPortEnum.D0, 5);
#19
I just ran that command with no errors - are you executing that method before or after the ez-b is connected?
#20
using System;
using EZ_B;
    static EZB _ezb;
        _ezb = new EZB();
        Console.WriteLine("Connecting to EZ-B v4...");
        _ezb.Connect("192.168.1.1");
        if (!_ezb.IsConnected) {
            Console.WriteLine("Unable to connect to EZ-B v4");
            return;
        Console.WriteLine("Hello World, I am moving servo d0 to position 90!");
        _ezb.Servo.SetServoPosition(Servo.ServoPortEnum.D0, 90);
        _ezb.Disconnect();
#21
Setting the fine tune after the servo position is set is backward approach.
Try this...
using System;
using EZ_B;
    static EZB _ezb;
        _ezb = new EZB();
            return;
        _ezb.Disconnect();
Set the fine tune before you use the servos - because that's an offset which the servos will require.
PS, thanks for wrapping your code:D Much easier for my eyes!
#22
I tried exactly the same code as you posted, but the same error:
[u]bsp.cs(12,14): error CS1056: Unexpected character ' bsp.cs(12,21): error CS1056: Unexpected character ' bsp.cs(12,25): error CS1056: Unexpected character ' bsp.cs(12,31): error CS1056: Unexpected character ' bsp.cs(12,31): error CS1525: Unexpected symbol Fine', expecting ,', ;', or =' bsp.cs(12,36): error CS1056: Unexpected character ' bsp.cs(12,42): error CS1056: Unexpected character ' bsp.cs(12,49): error CS1056: Unexpected character ' bsp.cs(12,55): error CS1056: Unexpected character ' bsp.cs(12,60): error CS1056: Unexpected character ' bsp.cs(12,70): error CS1056: Unexpected character ' bsp.cs(12,70): error CS1525: Unexpected symbol 5', expecting ,', ;', or =' Compilation failed: 12 error(s), 0 warnings [/u]
#23
Not sure where those errors are coming from - but looks like something broken in Mono (not surprising). Try reinstalling mono? Ensuring you have the latest version and dependencies? There are no known issues with the entire EZ-Robot mono library - i ran the entire test last night.
When googling the error "error CS1056", it could be caused by a European character in code: https://msdn.microsoft.com/en-us/library/59k0x971.aspx
Mono, like most programming languages, it not friendly to all character sets. Given that it's complaining about the commas "," and semicolons ";" or something.
#24
It indeed looks like strange unicode characters in your code. For example, when i copy and paste the errors that you posted into Notepad.exe, this is what i see.
Notice how after filtering the code that you posted through notepad (Which removes any bits outside of the ascii-7 charset), displays different errors.
Somehow, your keyboard is putting strange characters into the code while you type.
