Cognitive Vision icon Cognitive Vision — Microsoft Cognitive Vision integration for ARC: real-time object, face, emotion detection, OCR, confidence data and script-triggered robot actions. Try it →
Microphone clap trigger on Darwin Mini
Microphone Clap Trigger On Darwin Mini
Working on a ROBOTIS Darwin Mini (OpenCM9.04 flashed with the ARC firmware from the Synthiam hardware page), connected to ARC over USB for now. Servos (XL-320s) move fine using Auto Position frames, so the control link seems solid. I’m trying to add a simple audio interaction: clap once to make the Mini do a "cheer" pose, and also capture a 2-second snippet of the clap/voice and play it back through my PC speakers. I added the Microphone skill and the waveform/levels look good. Manually pressing "Record" then "Export to Sound Board (EZB)" works-the clip shows up in my Sound Board (EZB) and I can play it. But I’m stuck automating it from a script and reliably detecting the clap.
Questions/issues I’m hitting:
  • I can’t find a reliable variable or event to detect a short, sharp clap; the Auto Record threshold triggers too often on ambient noise with my laptop mic. Is there a way to read a current mic RMS/peak value or get a boolean "above threshold" variable that I can debounce in JavaScript?
  • What are the exact ControlCommand strings for the Microphone skill to 1) start/stop a timed recording and 2) export the latest buffer to a specific Sound Board (EZB) control? I tried guesses like:
ControlCommand("Microphone", "RecordFor", 2000);
Sleep(2200);
ControlCommand("Microphone", "ExportToSoundBoard", "Sound Board (EZB)");
ControlCommand("Sound Board (EZB)", "Track_0");
but nothing updates on the Sound Board unless I click Export manually. Also, any tips for clap detection filtering (e.g., simple moving average) in ARC JavaScript so my Darwin Mini only fires the Auto Position frame on a real clap?
What is the correct way in ARC to read a clap-like peak from the Microphone skill and then programmatically export/play the latest recording via Sound Board (EZB) while triggering an Auto Position on a Darwin Mini connected over USB?
Darwin Mini by Robotis
Control Darwin Mini in Synthiam ARCx with firmware, servo animation, Blockly, JavaScript, Python, voice, and AI skills.
USB / Bluetooth
Servos 16
ADC ✕
Digital ✕
Soundboard (EZB) by Synthiam
Play WAV/MP3 via EZ-B v4, manage tracks, add timed scripts for synced robot actions, control via ControlCommand(), volume and clipping indicators.
Microphone by Synthiam
Record audio from your PC mic, auto-trigger and edit sample rate/effects, then play or export recordings to an EZ-B v4 SoundBoard for robot playback.
Yes - you can build this in ARC, but there are a couple of important limitations to know first:
What ARC can and can’t do with the Microphone skill
The Microphone skill is primarily a recording tool, not a live waveform analysis API. So:
  • There is not a built-in public variable that exposes real-time RMS/peak/clap level
  • There is not a simple "above threshold" value you can poll directly from JavaScript
  • The Auto Record feature is internal to the skill, so it’s not ideal for precise clap detection
That means the most reliable path is usually:
  1. Use the Microphone skill only for recording
  2. Do your clap detection externally in JavaScript or Python by reading from the mic input through a script-compatible path, or
  3. Use a small custom robot skill if you need true live mic level access
If you want a reusable solution inside ARC, the best long-term approach would be creating a custom robot skill: https://synthiam.com/Support/Create-Robot-Skill/Overview
About the Microphone skill commands
The exact ControlCommand() strings for the Microphone skill are not always obvious from the UI, and they depend on that skill’s documented commands. Since the public documentation doesn’t list a timed-record/export command set in the same way some other skills do, the safest way is:
  1. Open the Microphone skill
  2. Click the kebab/hamburger menu in the top-right of the skill
  3. Look for its settings/help/control command list
  4. In ARC, use the Cheat Sheet in the script editor to inspect available commands for that skill
If a command isn’t listed there, ARC won’t accept guessed names like "RecordFor" or "ExportToSoundBoard".
Important note about your Sound Board test
You mentioned:
manually pressing "Export to Sound Board (EZB)" works
That means the connection is fine.
But the export button is a UI action inside the Microphone skill, and many skills don’t expose every UI action as a ControlCommand(). So the issue is probably not your syntax - it’s likely that the Microphone skill doesn’t currently expose that export action through ControlCommand().
Best practical architecture for your goal
For your use case on the Darwin Mini:
  • Auto Position: trigger your cheer pose
  • Microphone: manual/automatic recording only if supported
  • Sound Board (EZB): play back the exported clip
  • JavaScript: handle the logic and debounce
Example flow
  1. Detect clap
  2. Trigger Auto Position "Cheer"
  3. Start recording for 2 seconds
  4. Stop recording
  5. Export recording if the Microphone skill supports it
  6. Play the sound from Sound Board
How to make clap detection more reliable
Because the built-in mic skill doesn’t expose raw live audio levels, you’ll need a workaround. Common options:
Option A: Use speech recognition / audio trigger style detection
If your clap is consistent and loud, you may be able to detect it with a short audio trigger window.
Option B: Use a custom script skill or robot skill
This is the cleanest solution if you want:
  • peak detection
  • moving average smoothing
  • threshold debounce
  • clap-only triggering
Option C: Use a Python/JavaScript loop with a separate audio source
If you have access to audio input via a scriptable source, you can:
  • sample mic data
  • calculate amplitude
  • compare against threshold
  • require a second "quiet" window before re-arming
Debounce idea in JavaScript
If you can get any kind of live amplitude value, a simple clap detector would look like this:
var threshold = 180;
var clapCooldownMs = 1200;
var lastClapTime = 0;
function isClap(currentLevel, smoothedLevel) {
  return currentLevel > threshold && smoothedLevel > threshold * 0.7;
function triggerCheer() {
  controlCommand("Auto Position", "AutoPositionAction", "Cheer");
while (true) {
  // Replace this with your actual mic level source if you have one
  var currentLevel = 0;
  if (currentLevel > threshold) {
    var now = new Date().getTime();
    if (now - lastClapTime > clapCooldownMs) {
      lastClapTime = now;
      triggerCheer();
  sleep(20);
That said, this only works if you have a real level reading source.
Triggering the Darwin Mini cheer pose
If your Auto Position action is named Cheer, then the ControlCommand would typically be:
If your control is renamed, use that exact title instead.
What I recommend you do next
  1. Open the Microphone skill’s hamburger/kebab menu
  2. Check whether it exposes any ControlCommands
  3. If it does not expose timed record/export commands, you’ll need either:
    • a custom robot skill, or
    • a different audio-detection approach
  4. Use the ARC AI Assistant inside the script editor to help rewrite or build the JavaScript logic directly: https://synthiam.com/Products/AI-Assistant
For your specific setup
Since you’re on a Darwin Mini over USB and your motion side is already working, I’d focus on two separate pieces:
  • Motion: trigger the cheer pose with Auto Position
  • Audio: handle clap detection using a more direct method than the Microphone skill alone
If you want, I can help you with either of these next:
  1. Write a clean ARC JavaScript debounce script for clap-triggered Auto Position, or
  2. Figure out the exact Microphone/Sound Board ControlCommands by walking through the skill menus with you.
If you can share a screenshot of the Microphone skill settings/menu and the Cheat Sheet for that control, I can help identify the exact command names.
