DHT11 Temp & Humidity Sensor icon DHT11 Temp & Humidity Sensor — Read DHT11 temperature and humidity on Arduino (signal pin 4) using EZ-Genuino_DTH11_Uno firmware; exposes $Temp and $Humid variables. Try it →
Meccano Rebuild
How to program a Meccanoid using ezb v4 with ez HDD servos? Some codes examples would be appreciated, thanks
#1   — Edited
hi
use the ARC off roli . same way as you would program a jd robot . you have to use all servo from ez robot in the meccanoid robot . they are same size . use a H-brige for the wheels from the mecanoid . witsh meccanoid do you have ? and are you going to use the ez robot camera?
