Netherlands
Twitter YouTube
With the EZ-B and ARC it's really easy. Just hook up a camera to your robot, configure it in ARC for motion tracking and you're done :D
O thanks, can you also make you robot follow your steps with the motion tracking?
The best way would be to have it follow something that specifically identifies you so it doesn't just follow anyone around. Glyph tracking or Harr tracking if you want to create a custom Harr. Xml file of something you uniquely wear or carry would work. Color tracking would also work. I have been planning on having mine follow an infrared led strapped to my ankle, although I wish we could track a specific blink pattern, again so it doesn't chase anyone using an ir remote.
Ireland
@thetechguru The ir beacon does that as it only responds to its own transmitter
Or I can put a band with a specific pater of colors in my leg so it doesn't follow anything else.
Diego, i'd go with the colors. Keep in mind that the tracking with be affected by brightness and strange lights. The lights at conference centers are usually a mesh of colors. And the brightness of each bulb is so high that it's an overwhelming number of photons for the camera CCD. I find a single polarization filter helps. Just a piece of polarized sheet cut and glued over the camera lens.
The other thing to consider is the brightness of the sun if the robot is outside. As the robot faces the sun, your body will cast a shadow - making it impossible for the camera to see colors. It will only see a large shadow in front of you.
In both of these cases, when the robot stops following you... I suggest carrying a WiiMote control in your pocket. That way you can slide your hand in your pocket and override the tracking.
Plus, you can assign a few buttons on the WIiMote to adjust tracking values. So you can adjust it in realtime.
thank you, I think the wii remote will a great idea. Because it will be very hard to fix the problem of the camera. If not I had an idea of having a gps or something that the robot can track in my pocket and the robot can follow that.
Does anyone knows how to make it?
