Translate icon Translate — Translate text via Microsoft Translator (auto-detect); EZ-B plugin stores translated and detected language variables. Requires Azure key. Try it →
yep found the mac adres.using an app calt find mac adres thru BT in few sec it shows up in the app.
1 connect your robot with phone BT 2connect your robot to pc BT 3then use the app
app looks like a radar.
is this chedule for engenius good ?
this sets your WiFi as enabled only from 11 am unail noon I believe. I wouldn't mess with the schedules.
I think we had setup a reboot of your router on a nightly basis. It has been almost 2 years since I set this router up for you. Unfortunately, I am beyond busy right now with a lot of other things. I won't be able to connect until maybe July 22nd. That all depends on if I have everything ready for a meeting later that week or not. Maybe while I am out of the country and work isn't hitting me with questions on or around July 28th I would be able to connect and get everything set back up.
hi david
the robots do connect,sometimes a hole session and sometimes 5 min. i ask this cause there's another robot in the mail.and this connects thru , qr code.and i was able to find the mac adres with a radar scan for BT, an it find all mac adresses,pretty cool tip from alan. i do have lots off time sinds there is also a problem with there server. if the robot has seen the qr code it chould find the server too. but thats not reddy yet.so take your time to rest also have famely time.
thanks for your respons.
anyone knows what these errors mean ?
found it means server is under maintenance.
