joinny
Japan
Leap Motion Combine With ARC To Control In Space
I'm trying to use LEAP Montion on ARC but I'm still not successful and I posted this question in the hope that someone in the community might be able to do it with their project. I think it would be perfect to combine it with kinect?
EZ-B V4
by EZ-Robot
EZ-B v4/2 robot controller: dual Cortex ARM, Wi-Fi, audio/video, 24 servo/digital ports, I2C/UART, camera and Synthiam ARC control for custom robots
Servos
24
UART
3
ADC
8
Digital
24
EZ-B Settings
by EZ-Robot
Configures and pushes WiFi SSID, password, system name and channel to EZ-Robot EZ-B v4 from ARC; saves settings with project for quick redeploy.
Requires ARC
v6
Servo Speed
by Synthiam
Adjust servo/PWM speed (0-20) between two positions to quickly experiment and tune motion; select board/port; settings aren't saved.
TCP Clients
by Synthiam
Monitor incoming TCP Server connections when TCP Server is enabled under Connection > Config; view and track live connections.
HTTP Server
by Synthiam
Remote web control of ARC desktop: live screen interaction, movement control, camera list, EZ-Script/ControlCommand console with remote execution.
HTTP Server (Custom)
by Synthiam
HTTP server for ARC serving HTML/CSS/PNG/JPG from ARC/HTTP Server Root; supports AJAX tags (ez-move, ez-script, ez-camera) to control the robot.
TCP Client
by Synthiam
Telnet-like ASCII TCP client for ARC: connect to IP:port, send ASCII, view raw or HEX server responses with local echo
Requires ARC
v8
Dynamixel
by Robotis
Open-source ARC plugin to control Robotis Dynamixel servos (XL-320, AX-12, XL430) via EZ-B, Arduino or Robotis. Supports position, speed, accel.
Requires ARC
v53
Well, I was wrong when I wanted to combine the leap with motivation and effort a few days I discovered that it was useless. In addition to plugins, I am also not familiar with creating such an animated interface in ARC and I will probably take some time to research and create it. Thanks for the answer
Does the leap motion have a joystick mode? Where it can emulate an analog joystick?
if so, use the joystick skill control in ARC.
Yes, of course the leap montion can be used for joysticks, every simulation of the arm and hand is done with the deap montion. Thanks for your great suggestions!
