Oculus Quest Robot icon Oculus Quest Robot — Immersive Meta Quest VR control for Synthiam ARC robots: stereoscopic camera view, map servos to hands/controllers, plus built-in remote desktop. Try it →
Japan
Leap motion combine with ARC to control in space
Leap Motion Combine With ARC To Control In Space
I'm trying to use LEAP Montion on ARC but I'm still not successful and I posted this question in the hope that someone in the community might be able to do it with their project. I think it would be perfect to combine it with kinect?
EZ-B Settings by EZ-Robot
Configures and pushes WiFi SSID, password, system name and channel to EZ-Robot EZ-B v4 from ARC; saves settings with project for quick redeploy.
Servo Speed by Synthiam
Adjust servo/PWM speed (0-20) between two positions to quickly experiment and tune motion; select board/port; settings aren't saved.
TCP Clients by Synthiam
Monitor incoming TCP Server connections when TCP Server is enabled under Connection > Config; view and track live connections.
HTTP Server by Synthiam
Remote web control of ARC desktop: live screen interaction, movement control, camera list, EZ-Script/ControlCommand console with remote execution.
HTTP server for ARC serving HTML/CSS/PNG/JPG from ARC/HTTP Server Root; supports AJAX tags (ez-move, ez-script, ez-camera) to control the robot.
TCP Client by Synthiam
Telnet-like ASCII TCP client for ARC: connect to IP:port, send ASCII, view raw or HEX server responses with local echo
Dynamixel by Robotis
Open-source ARC plugin to control Robotis Dynamixel servos (XL-320, AX-12, XL430) via EZ-B, Arduino or Robotis. Supports position, speed, accel.
ARC does not have a plugin for Leap Motion are you developing a plugin ? Can you be more specific regarding the problem you are facing ?
The Kinect requires a good 6 to 10 feet of space between the user and it and leap motion requires a hand on top of the sensor do you think they can fit together ?
#2   — Edited
Well, I was wrong when I wanted to combine the leap with motivation and effort a few days I discovered that it was useless. In addition to plugins, I am also not familiar with creating such an animated interface in ARC and I will probably take some time to research and create it. Thanks for the answer
 I'm not saying leap is not worth a shot... leap is a table device and kinect is room device. Hand versus Body tracking.
To ARC requires a plugin to interact with a hardware device. To develop a plugin you need the hardware, motivation and the skills to develop a plugin.
If you have the hardware and some development skills (Visual Studio / c#) you should try. I believe the graphic interface (i.e. hand) you see in the video is a leap user tool. An ARC skill plugin does not require animated/graphics design, but, it's important to have a good knowledge how the hardware i.e. leap works, existent APIs and an idea how to export the device features to the ARC.
Does the leap motion have a joystick mode? Where it can emulate an analog joystick?
if so, use the joystick skill control in ARC.
Yes, of course the leap montion can be used for joysticks, every simulation of the arm and hand is done with the deap montion. Thanks for your great suggestions!
