SMTP Client icon SMTP Client — Send SMTP email (text or camera images) from ARC robots via ControlCommand; configure SMTP/auth and sender; saves credentials in project. Try it →
Just Received Ezb V4 Controller With Camera.No Power Supply Included? From Re Se
https://www.robotshop.com/en/ez-b-v4-wifi-robot-controller-with-camera.html#productsReviewBoxTitle
EZ-B V4 WiFi Robot Controller with Camera Product Code : RB-Ezr-16 by EZ-Robot
I was thrilled to receive this in one day, free shipping from Robot Shop.. But didn't received Power Supply? No where does it state the power supply is separate and the controller was in a plastic sealed EZ Robot box. The item description says : Includes 1 Power Shell...isn't that the Power adapter?
What's Included: 1 x EZ-B v4 Camera 1 x EZ-B v4 Wi-Fi Robot Controller 1 x Power Shell ez-builder robot control software and SDK
Was the Power Supply supposed to be included? where do I get it?
Thanx; Rob:)
I would use the second one. 1000mah is pretty low amps. The ones that EZ-B sells are 1300mah and I don't think they last long enough. 2200mah will give you decent use between charges.
Thanx,:) and these guys are in VT and I'm in NH... get delivery in one day:)
Rob
the battery is very interesting:
https://www.robotshop.com/en/dfrobot-7-4v-lipo-2200mah-battery.html
is not a plain vanilla 2S lipo battery, there is a built in circuit to stop charging automatically.
also the charger: https://www.robotshop.com/en/74v-lipo-battery-charger.html
is not a regular (JHT connector) lipo charger.
some guys use the battery as "always-plugged-in" that possibility is very interesting if you want to implement a charging station.
sometime ago i asked the question in their forums, but nobody confirmed the "always-plugged-in" scenario.
I think for a EZ Roli a always-plugged-in battery would be something very useful.
