Hello,
I would like to inquire if there is a simulator available for the JD Humanoid robot. I have been informed that the robot will arrive in approximately two months. However, our academic semester has already commenced, and we are eager to begin working with the robot as soon as possible to avoid any delays in our learning process.
Thank you.
Hello! It's great to hear that you're eager to start working with the JD Humanoid robot. While you wait for your robot to arrive, you can use the Avatar JD robot skill as a simulator. This skill allows you to interact with a virtual 3D version of the JD Humanoid robot, which can be very helpful for getting familiar with the robot's movements and capabilities.
Here's how you can get started with the Avatar JD simulator:
Install ARC: Make sure you have the latest version of ARC installed on your computer. You can download it from Synthiam's website.
Add the Avatar JD Skill: In your ARC project, add the Avatar JD skill. This will give you a virtual representation of the JD Humanoid robot. Get it from the "Remote Control" tab when adding a robot skill. The manual is here: https://synthiam.com/Support/Skills/Remote-Control/Avatar-JD?id=19315
Interact with the Simulator: You can move the virtual JD by clicking on its body parts and dragging them. This will help you understand how the servos work and how to create different poses and movements.
Create Action Sequences: Use the Auto Position control to create action sequences and test them with the virtual JD. This will allow you to plan and refine your robot's movements before your physical robot arrives.
Use the EZ-B Emulator: If you don't have the JD Humanoid yet, you can use the EZ-B Emulator to simulate the robot's behavior. Set the emulator to
EZB_v4_OS_With_Comm_1and check theListeningcheckbox. Then, connect to127.0.0.1:23in ARC to simulate JD's actions.By using the Avatar JD skill, you can start learning and experimenting with the JD Humanoid robot's capabilities, ensuring that you're well-prepared when your robot arrives. If you have any questions or need further assistance, feel free to ask!
